It is currently Tue Jan 23, 2018 8:49 pm
 Post subject: mk3 1.2 lx
PostPosted: Fri Jul 01, 2011 11:05 am
Mum has done a crazy thing, and bought a mk3 1.2 lx for 350 quid.
84000 miles, looks mint inside, need some work on the fuel cap...
but other than that, the car looks sound.
Now, I can take it on, not my first choice, but could be a good base for something.
Or give it to her boyfriend, who will need a car VERY soon.
Engine mounts are the same as? What bigger fiesta engine drops in easily? RS turbo lump?
Brakes and what not as well?
Suspension, can just get coilovers, or shocks and springs.. anything else, with the suspension?
any other little add ons, things to make it most desirable to me? :P
1st post ;)
Couldn't remember my old account details.
 Post subject: Re: mk3 1.2 lx
PostPosted: Fri Jul 01, 2011 11:19 am
All engines drop in about the same on difficulty basis from the sub 1.6's. Brakes, best served by braided lines and a mondeo master cylinder and servo. Unless you're wanting to throw money at a full conversion just service any parts such as the suspension, as things can get confusing, what year is it? Is it a MK3 or MK3.5 as that makes huge differences with regards to suspension.
Go down your scrappy, and raid every fiesta you can, always good to have parts knocking around.
PostPosted: Fri Jul 01, 2011 11:24 am
My old fiesta is probably kicking around the old scrappy! lmao!
unless it's been cubed! aha.
It's a 93 I believe. mk3.
Mondeo 2l brakes then?
PostPosted: Fri Jul 01, 2011 11:43 am
Drives: Si 1.6 & ST170
I dont know about mk3s but people usually stick st150 brakes on the mk3.5s as they are a direct bolt on.
The Loumiester wrote:
PostPosted: Fri Jul 01, 2011 5:56 pm
Drives: Fiesta 1.4 cvh
mk2 mondeo brakes fit with just the caliper carrier bolt drilled out to 12mm, shocks and srings combo way cheaper than coilovers for a mk3
PostPosted: Fri Jul 01, 2011 5:57 pm
is it a 3 door or a 5 door? as i have a full xr2i/rs1800 kit for sale cheap
PostPosted: Fri Jul 01, 2011 7:43 pm
Cant be a 1.2, must be a 1.1.... if the shell is any good, keep it, use it, upgrade the engine.
Simple - 1.6 cvh.
More complex - zetec.
Brakes: ST150
Bodywork: Leave standard for the sleeper look.
Wheels + Tyres: Subtle - sleeper look.
Suspension: Coilovers all the way from personal experience with both shocks and springs + coilovers... if you cant afford it, just get shocks and springs, gmax are cheap, spax are better though.
Then go from there.
PostPosted: Sat Jul 02, 2011 3:48 pm
1.2 lx 5 door :p
only made lx in 5 door for the 1.2 i believe!
ill check it over when i see it, if not, ill buy a zetec s :D
PostPosted: Sat Jul 02, 2011 5:04 pm
Drives: C2 VTS
It has to be a 1.1 or 1.3 if its a mk3/mk3.5 the 1.25s came in with the mk5 (maybe late mk4s)
PostPosted: Sat Jul 02, 2011 8:41 pm
Meh! Find out when we get it..
PostPosted: Sat Jul 02, 2011 8:48 pm
The mk3 kent/HCS range was
1.0 45ps
1.1 50-55ps
1.3 60ps
PostPosted: Mon Jul 04, 2011 9:35 pm
Well, I'll find out on Saturday, should be picking it up then.
But I won't be having it.
Just bought a 1.7 zetec s. aha.
PostPosted: Mon Jul 04, 2011 9:45 pm
Drives: C2 VTS
Good stuff!
PostPosted: Mon Jul 04, 2011 10:24 pm
Drives: mondeo st tdci
the 1.25 is in the mk4 onwards
Users browsing this forum: Bing [Bot] and 5 guests
