It is currently Tue Jul 17, 2018 11:05 am
PostPosted: Sun Jun 12, 2011 11:35 pm
just wanting to know what mods i can do as im new to mk3 fezzas
brakes: what the best front brake setup i can fit and also can i put discs on the rear
suspension: does the mk5 zetec s suspension fit the mk3
PostPosted: Sun Jun 12, 2011 11:47 pm
Drives: mk3 si & mk2 mr2
best things to do imo is: poly bushes, braided brake hoses with good pads, uprated shocks and good tyres.....
mk5 suspension dont fit as a straight swap, you could probably make it fit but wouldnt be worth the hastle...
as for rear discs, ive never tried these but from what other people who have them told be is there not worth doing for performance but as more of a looks thing
hope this helps ya mate :thumbsup:
PostPosted: Mon Jun 13, 2011 12:00 am
Drives: Si 1.6 & ST170
St150 front brake set up is a bolt on mod but you need a minimum of 15" wheel
You can get a rear disc conversion kit from fiesta centre.com but as said the word is they aren't needed.
The Loumiester wrote:
PostPosted: Mon Jun 13, 2011 12:18 am
thanks guys iwill leave the rear disc mod then and im after a set of 15" mk5 zetec s wheels
PostPosted: Mon Jun 13, 2011 12:19 am
and that mk6 st 150 isnt it
PostPosted: Mon Jun 13, 2011 12:23 am
yeah mk6 st150 as loumiester said :thumbsup:
PostPosted: Mon Jun 13, 2011 12:25 am
nice one chaps
PostPosted: Mon Jun 13, 2011 2:30 pm
Drives: Fiesta 1.4 cvh
or you can use mk1/2 mondeo V6 front brakes that use a 278mm disc, cheaper than st brakes and much easoer to find in a scrappy, only mods you have to do are drill the caliper carrier mounting holes on the hub to 12mm, if using mondeo discs you will need 3mm spacets to gp between the hub amd the disc or you can use st170 discs or 4x4 cosworth discs (i think), then all ypu need is 15" wheels
PostPosted: Mon Jun 13, 2011 3:46 pm
Drives: 2004 Volvo S60 D5
Or you can use Mondeo MK3 calipers and pads with Focus ST170 disks - requires caliper mounting holes bored out, but the disks go straight on.
The price of this is in between the ST150 setup And the Mondeo V6 setup.
They are 300mm disks so minumum wheel size is 16" unless you get bigG1985's setups he makes, so you can get the whole kit new for i think it was £175, which is a few quid more than a second hand ST150 setup, but it's better and new.
This is the 300mm setup i bought from bigG, with 16" Mondeo Zetec wheels:
The calipers have been modded to fit Escort GTi wheels, but he can also do it to fit Zetec-S wheels too
PostPosted: Mon Jun 13, 2011 11:35 pm
The first braking mod you should do on a MK3 is get a Mondeo Servo and Master Cylinder and get braided lines.
PostPosted: Tue Jun 14, 2011 1:03 am
thanks again chaps much appreiciated
