It is currently Thu Jan 18, 2018 6:41 pm
 Post subject: uprated exhaust mounts
PostPosted: Fri May 20, 2011 2:55 pm
Drives: 2.0 si
where can i get a full set of performance exhaust mounts for a mk3.5 fiesta i can only seem to find rear mounts or is that all thats available?
Thanks jamie :thumbsup:
PostPosted: Fri May 20, 2011 6:17 pm
Halfrauds, burton power, rally design, demon tweaks.
All you needs is the rear style ones for the whole system, apart from that is just the two on the cat, not sure you can get them in poly form, but might be able too :)
PostPosted: Fri May 20, 2011 6:30 pm
Drives: 2004 Volvo S60 D5
Front ones are just rings aren't they? I think i've seen ones like that on the FloFlex website, think they were for a land rover or something
PostPosted: Fri May 20, 2011 7:20 pm
Yeah pretty much, like an oval with the strenghtening bit going across the middle
PostPosted: Fri May 20, 2011 7:31 pm
Drives: 2.0 si
would anyone be able to check demontweeks for me as i dont know what shape im looking for they have 10 universal types
PostPosted: Fri May 20, 2011 7:42 pm
Couldn't find the front rings, but i found ones exactly the same as standard mounts, but in poly http://www.floflex.co.uk/product_info.p ... cts_id=630
PostPosted: Fri May 20, 2011 7:46 pm
Drives: 2.0 si
demontweeks have a good selection if noone knows then ill have mine off my car on sunday and have a look :)
PostPosted: Fri May 20, 2011 7:52 pm
http://www.demon-tweeks.co.uk/Search.do ... aust+mount
Im sure they are 002, might be worth a check though. ill see if any of my pics have them in for you.
PostPosted: Fri May 20, 2011 7:56 pm
Drives: 2.0 si
ok thanks mate :D
PostPosted: Tue May 24, 2011 11:47 pm
i had a set on my si but took the ones off the cat as there was no movement and resulted in snapping the bracket on the cat
PostPosted: Wed May 25, 2011 9:50 am
Drives: 2.0 si
i ended up getting just the rear ones they were code 005 diamond shaped with the m shaped hole in the middle
