It is currently Wed Feb 21, 2018 12:11 pm
 Post subject: rubbing on inside arch
PostPosted: Sat Apr 23, 2011 3:01 am
Drives: si 1.4 8v
was just wondering if anyone had any suggestions on how i can stop my wheels rubbing on the inside arch. Iv got rs2000 alloys on bog standard shocks. I was rubbing badly but iv put some 10mm spacers on which has stopped it alot, but theres still abit of rubbing occuring on full lock
PostPosted: Sat Apr 23, 2011 10:11 am
Drives: Si 1.6 & ST170
What tyres you got on there?
The Loumiester wrote:
PostPosted: Sat Apr 23, 2011 12:55 pm
Drives: Fiesta ZS
You need 5mm spacers on the front, maybe you've spaced them a bit too much which has caused rubbing on another part.
Good choice on alloy though ;)
PostPosted: Tue Apr 26, 2011 9:38 am
Drives: MK1 Focus Estate Ghia
Get different tyres
Don't use full lock
Get some clips to stop you using full lock
PostPosted: Tue Apr 26, 2011 12:13 pm
Drives: Fiesta 1.4 cvh
are you using 195/50r15's or 195/45r15's? also have your tracking checked? or check your shocks, if one is weeping fluid it will be lower causing the tyre to rub on full lock, i'm using 45 profile tyres on the same wheel with 3mm spacers and it only just rubs agaist the wheel arch liner on full lock
PostPosted: Wed May 18, 2011 2:51 pm
you can get clips to stop full lock!?
and yes, mine rubs slightly when on full lock... solution, dont use full lock as peeps have said
PostPosted: Wed May 18, 2011 3:56 pm
Yep ;)
linkageeee paul!?
