It is currently Tue Jun 19, 2018 3:38 am
PostPosted: Sun Mar 27, 2011 8:57 pm
Drives: 1.6si
Hi guys what cluch kits do you reckomend, budgets 150.. I tend to like engine braking a lot, bieng first away from the traffic lights with out any thing going bang! Needs to be ok around town also any ideas?
Thanks guys
Tiababy is a Legend...
THE DON..... DON DIGGLER
PostPosted: Sun Mar 27, 2011 9:06 pm
Drives: 1.6si
http://www.demon-tweeks.co.uk/Performan ... 9213/28500
PostPosted: Sun Mar 27, 2011 10:15 pm
Drives: mondeo st tdci
what sort of power will you be running ?
PostPosted: Sun Mar 27, 2011 10:19 pm
Drives: Si 1.6 & ST170
Alot of people just stick with the standard clutch as its the same as the rs turbo one and thats good for 130bhp which is only 6bhp short of a silver top 2.0
The Loumiester wrote:
PostPosted: Mon Mar 28, 2011 8:37 am
Drives: 1.6si
I have a silvertop out of a 4x4 its 136bhp :O)
PostPosted: Mon Mar 28, 2011 8:56 am
I know so the standard clutch should do but if you want piece of mind then people usually get a black diamond clutch.
PostPosted: Mon Mar 28, 2011 10:18 pm
std clutch will be fine then
PostPosted: Tue Mar 29, 2011 1:15 pm
Drives: Si 2.0 16v
the pressure plate and bearings are the same the actual friction plate of the rs1800 has heavy duty springs compared to the rs turbo
Rolling a 2.0lt Si, Cams, Stainless Manifold, Ported head and HO, Custom exhaust, Lack of Cat, CRAPPY GMAX suspenstion.. Powerflexed front wishbones, Cossie brakes :D
PostPosted: Tue Mar 29, 2011 1:17 pm
Drives: C2 VTS
I would be suprised if you get the full 136bhp.
My old 2.0 as runnign closer to 145bhp (we think) and it was on a black diamond clutch with no issues.
PostPosted: Tue Apr 19, 2011 8:55 pm
Drives: V6 Cougar
what he said :thumbsup:
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sat May 07, 2011 5:42 pm
Drives: 1275 gt mini :)
just done a conversion and using a cheaper ap racing clutch cost me 110 quid i think and its awesome!
PostPosted: Mon May 23, 2011 9:01 pm
just put a black diamond clutch in mine doesnt slip no more :)
PostPosted: Thu Aug 04, 2011 5:31 pm
the standard zetec clutch is fine for upto about 150bhp so you should get any issue swith it, after 150 it will start slipping when you floor it
engine braking wouldnt have an effect as the engine power/torque is not whats going to cause slip, its matching the engine speed tot he road wheel speed :P
PostPosted: Mon Nov 28, 2011 12:28 am
Drives: 1.6si
What do you use if you want more than 150 hp? i saw some figures that a silvertop with bike carbs can push out upto 180 hp and if thats the case thats the way im gona go :P
Users browsing this forum: Exabot [Bot] and 4 guests
