Fiesta-Si.com • View topic - fitting mondeo v6 brakes
It is currently Fri Mar 06, 2026 1:42 pm
 Post subject: fitting mondeo v6 brakes
PostPosted: Wed Aug 05, 2009 4:21 pm
just got a set of mondeo v6 brakes with everything there (calipers, carriers, pads, discs, flexis) off an s reg mondeo (mk2?)
just wondered how do i fit em on my si? coz they dont fit straight on do they?
PostPosted: Wed Aug 05, 2009 10:12 pm
Drill the hub holes out to 12mm.
Space the discs out 3mm.
Might have to cut down the caliper bolts to stop them fouling the disc, but you'll see.
Bleed them up.
Done.
PostPosted: Wed Aug 05, 2009 11:23 pm
is it that simple? my mate sed about spacing the caliper out? and using cossie 4x4 discs so they dont need be spaced out?
PostPosted: Thu Aug 06, 2009 12:39 am
found this:
http://www.escortevolution.co.uk/forums ... opic=93596
on an escort that is thou.
says to use cossie discs and space calipers out to line up with the disc. which is what mate sed to do.
PostPosted: Thu Aug 06, 2009 5:43 pm
The V6 brakes fit.
Space the DISC out 3mm. Just bolt the caliper up.
Done it plenty of times on fiesta escorts and pumas
PostPosted: Thu Aug 06, 2009 5:47 pm
aint it dangerous to space out the disc using washers or watever thou?
PostPosted: Thu Aug 06, 2009 6:24 pm
and how was you planning on spacing the calipers out???
ive never had a problem.
PostPosted: Thu Aug 06, 2009 6:55 pm
difference is calipers are securely bolted to sumin whereas discs aint.
PostPosted: Thu Aug 06, 2009 7:11 pm
PostPosted: Thu Aug 06, 2009 8:06 pm
golf mk4 discs arnt held on by anything well the ones at work ive done arnt so i dont see why the disc spacing is a problem its only 3mm aswell mate thats nothing do your wheel nuts up tight and your away the day after you do them check the wheel nuts as the washers might have comprsed a bit more
PostPosted: Thu Aug 06, 2009 8:19 pm
Alrite fair enuff. ill use spacers with mondeo discs.
so just put 3mm washers over the studs then put the disc over them yea?
wa bowt calipers? need to do anything to them?
PostPosted: Thu Aug 06, 2009 8:30 pm
PostPosted: Thu Aug 06, 2009 8:34 pm
ok. ill write back if i get any problems
PostPosted: Fri Aug 07, 2009 12:20 am
condsider a set of escort disks which are 3mm or more less (front to back depth) that should avoid the spacing issue.
I was considering this meself
Fezzie Si 1.6 1995
PostPosted: Fri Aug 07, 2009 1:02 pm
Thas y my mate sed to use cossie discs.
PostPosted: Sat Aug 08, 2009 1:03 am
i think its silly using the mondeo disks, you're gonna have 3mm less thread on the wheel studs, dont see where the need to bodge things on are, not just on about you dan im on about everyone whos done it, it just seems needless risks.
Msn - ryan@areyouserios.com
PostPosted: Sat Aug 08, 2009 9:45 am
PostPosted: Sat Aug 08, 2009 3:13 pm
PostPosted: Sat Aug 08, 2009 5:31 pm
I dont mind what way i do it tbh. its a lot cheaper to do it using mondeo discs. and supose 3mm isnt much considering the size of the studs.
ive bought the washers to do it now anyway, and painted the calipers and carriers red. :)
PostPosted: Sat Aug 08, 2009 6:47 pm
Good luck :)
Ive just fooked around with one of my mondeo mk3 calipers.. damn thing kept sticking, think ive sorted it now lol
