It is currently Fri Jan 18, 2019 8:05 pm
PostPosted: Wed Jan 02, 2013 1:47 pm
Hello all.
I want to try and sell this lot as a package, but if i can, i will keep the board and just sell the bindings and boots to who ever wants them.
The Boots are vans Fargo, UK size 11. I bought these in 2009 and have used them for 3 one week holidays, so around 18 days use. They have a few marks on them, mainly from bindings, but a few little scuffs on the front, a good clean ( if you are that way inclined ) should suffice. Otherwise they are perfectly working and havnt lost any of their stiffness since the day i bought them. Boa system works faultlessly.
From Vans;
The Vans Men's Fargo Snowboard Boot offers medium-stiff flex for superior support with enough give to lay down an epic array of big airs and high-speed assaults on everything from abandoned burger joints to backcountry booters. Because being towed into hits and urban features by a sled or a beater pickup is just as much a part of snowboarding as lift-access resort riding.
Dial-in a tight fit at lightning speed thanks to the BOA H2 coiler closure system and custom Vans BOA tongue guides
Vans Quadfit Asym-X Thermal Liner creates an anatomically sound and supportive fit
Vans V-Tread Air Snowaffle Sole offers killer traction and has dual gel/air dampening in heel and gel cassette in the forefoot for increased cushion and comfort
Molded backstay adds support
RECCO rescue reflector in boot for increased safety
K2 Formula bindings. Again, 2009 purchased and have done the done same 3 weeks. Perfect working order. The only downside is cosmetic. Some of the paint is flaking off the main part of the binding. Its not an issue and could always be repainted in a colour to suit you. These are a large.
From K2
Lightweight precision paired with energetic response and superior mobility, the Formula is built to handle the city, backcountry and everything in between.
A favorite among the K2 team, the Formula comes fully loaded with our Motion Chassis and adjustable Aluminum Heelcup for the perfect boot-to-binding fit, empowering leverage and outstanding durability. Airframe Highback with VFL and Classic Caddy Ankle Straps design take ergonomic comfort to new levels, optimizing lightweight performance and seamless mobility.
Construction Features:
+ chassis: Motion Chassis w/ Adj. Aluminum Heelcup
+ Footbed: Tool-Less Adjust Power Ramp & Seam-Less EVA Footbed
w/ Pop-Top Disc Cover
+ Disc: Multi-Compatible Discs
+ Highback:Airframe w/ VFL Highback
+ Ankle Strap: Classic Caddy Ankle Strap
+ Strap Features: Hinge Mount & Tool-less centering adjust
+ Toe strap:Tool-less Universal Toe Strap
+ Ratchet: NEW! LiteSpeed EZ Feed Aluminum Ratchets
The board. A salomon Substance 161. I dont no much bout the board to be honest. I bought it from a friend of mine who used it for a week and changed to something smaller. I then used it for a week before changing to something funkier. I was going to keep it as a back up board or for something to use over here if it ever snows, but it just seems a waste to just let it sit there.
Has a few marks in its top, but nothing serious. Again, a few marks underneath, but nothing to worry about on a cheap board.
From the interweb
Easy riding with all-mountain versatility. Long lasting accessible power. An affordable option for avoiding the rental shop line, the Substance gets you into your own gear. Get comfortable with an easy turning sidecut, a forgiving core and a fast graphite base. Save money for lift tickets, spend more time on the hill and reach the next level.
Sidewall Construction
Wood Core: full length aspen with high density birch strips for improved insert retention.
Fiberglas: cross grain, flex optimized.
S Base 1500 Graphite: the best compromise between high performance glide in every snow condition, great durability and low maintenance.
Im putting it up for £200 as a starting price as im not to sure what its all worth.
Feel free to make me an offer on any one thing if you so wish.
Im based in West Sussex if anyone wishes to come and have a look or try the boots on etc.
Boots
Boot Liner
Bindings
Board
PostPosted: Sun Jan 06, 2013 11:54 pm
Now with board, full description and pictures
