It is currently Fri Jan 18, 2019 6:47 pm
PostPosted: Fri Mar 20, 2015 9:39 am
Drives: mondeo st tdci
got the following rs1800 parts for sale
bc zetec flywheel £40 posted
zetec bc gearbox sandwich plate £20 posted
kn banana induction kit and rs1800 maf £45 posted
rs1800 zetec ecu 130bhp and full ecu loom including injector loom, crank loom and edis 4 module.
ecu and loom are pre pats external edis £130 posted
ho zetec inlet manifold assy includes injectors and sandwich plate, throttle body, throttle postion sensor and icv
£90 posted
rs1800 engine
comes with exhaust manifold front water pipe coil pack
will probably need either a sump gasket or crank seal £100 collected
alloy zetec thermostat housing in very good condition very solid. front cover is partly polished
bare housing no sensors. outlet / inlet pipes all solid £70 posted
escort 130bhp zetec ecu non pats external edis 350 posted
PostPosted: Wed Feb 24, 2016 10:58 pm
Hello, is it actual?
I'm ready to buy alloy thermostat housing)
Thank's.
