It is currently Sun Jul 22, 2018 11:56 am
PostPosted: Tue Jun 24, 2014 12:05 am
(£70 the lot)
I need to clear my garage out asap as my si is hopefully coming off the road and i already have a project ka in the garage and i want a mustang so all my spares need to go to make room and are dirt cheap im happy to do deals with parts etc it just needs to go :)
i cant post overseas
I can post smaller items and larger items needs to be worth my while to post them as the items are very cheap and i can bring parts to ford fair but id like them paid for via paypal beforehand so i dont have to go back home with them
will sell everything for £70 if someone wants the lot will need collecting tho
i have pictures of all items if need be
location chelmsford essex
mobile number 07926872886
fiesta xr2i cvh ecu £10
Xr2i cvh water hoses full set £5
16 alloy wheel nuts £5
8 alloy wheel nuts with caps £4
Zetec coil pack £5
Mallard green si spot light surround right side £3
Nearly new si pas track rod end £2
2x Rear wiper motors £2 each
4x genuine ford zetec cat exhaust hangers 50p each
2 brand new pattern zetec exhaust hangers £2
Zetec fiesta mk3 thermostat housing £3
Horn £1
left side si fog light surrounds one black and one green £3 each
3x fiesta door handles part number (a22401) £1 each
zetec 2.0 crank seals brand new fai, £2
1 clear side wing repeater £1
2x window winders £1 each
2x xr2i arch fittings (the ones that rivet to the sill and the bodykit sits on them) £4 the pair
2x zetec water pump pulleys £2 each
1.3 mk4/mk5 iscv brand new £2
Brand new valeo headlight bulb cover £2
4x amber oval side repeaters 50p each
3x nearside clear front indiactors 2 are genuine ford £2each
door handle part number a22400 £1
Brand new 1.1/1.3ohv crank seals in box genuine ford £2
1.3 inlet to spi unit gasket brand new genuine ford £1
Zetec inside steering rack limiters brand new £10
Rear view interior mirrors x2 50p each
courtsey light £1
Complete handbrake lever from a 1990 xr2i £1
Zetec clutch fork £1
Bonnet red lever catch missing spring, 50p
brand new ford vistoen heater matrix for all mk3 fiestas £15 quid
zetec fuse box with all relays and fuses £2
Digital clocks one pats one non pats, £2 each
xr2i early type electric window switches and boot realese in panel £5
4x screen wash pumps, 50p each
2x front fog light switches £3 each
4x rear fog light switches £1 each
1x heated rear screen switch £1
2x brake light switch £1 each
3x lights on buzzer relays £1 each
3x handbrake switches 50p each
1x heater coil £2
X3 door pocket electric window switches £2 each
X2 dash dial surrounds 50p each
air vents x3 left x3 right and 2 centre ones 50p each
3x temperture panels 50p each ( the bit that you slide across for hot or cold settings
X12 door catch surrounds 50p each
4x dash ash trays 50p
x10 grab handles 20p each
bonnet cables x2 £1 each
zetec manifold with egr £2
Zetec front gearbox mounting £2
4 steering coloumn alinement surround/bearing tube £1 each
zetec top cambelt cover £1
Pair of scuttle panels nice and straight £2
3x fiesta si steering wheels 2 early airbag ones 1 later £2 each got airbags if needed
brand new si pas steering rack gaiters £2 each
Manual rack steering rack gaiter brand new £2
Powder coated zetec rear gbox mounting £3quid
2 escort gti alloy wheel centre caps £5 each
2 airbags free (will not post)
1x richbrook leather gear stick gaiter never fitted £2
mk3 fiesta jacks with wrench £1
Xr2i cvh alternator mounting with adjuster £1
Complete airbag loom and sensor box £2
3x rear bumper air flaps £1 each
3x front panel bonnet catch bars (bolt behind bonnet catch and bolt to the crossmember) £1 each
front wiper motor and linkage £3
Early mk3 fiesta pedal box £2
Zetec s/ ford puma 1.6 starter motor £5
N/s front 5 door electric window motor £5
mk3.5 drivers side door wing mirror £4
Xr2i side mouldings in blue one front wing one missing from set £5
N/s pas wishbone good bushes etc £2
X2 manual steering columns £4 each
cvh gearbox member £3
Front wiper motor £2
C/locking motors pair £2
2 xr2i rear quarter card grey, £2pair
n/s black rear quarter card £1
Loads of seat belts all avaliable £1 each
parcel shelf supports no speakers £2 pair
cvh air box from xr2i £4
Black dash glovebox doors £1each
interior mirror base plates 2 early types and 2 later types £1 a pair
carbon wrap mk3 early wing mirrors £4 pair
zetec fan motor no surround £1
Pair of mk3.5 front hubs with new wheel bearings and flanges £10 each covered little miles
cvh xr2i rear engine mount £5
3 speedo cables £1 each
Zetec si crossover pipe £3
Xr2i dials with rev counter £4
Black centre consol £2
Wiper heater blower cover £2
n/s valeo ford headlight £2
Cvh iscv £1
Standard gearknob £1
bonnet hindges £1 pair
Rear bulb holders 50p and pair
mk3.5 wing mirror casings one colour coded £free
mk3 steering coloumn grommit £1
Door pockets for electric window models £2 pair
pillar covers all types 50p each
pas bottle mount £1
Steering lock £2
Xr2i crossover pipe £3
Wiper motor and linkage £3
Zetec, cvh, and ohv engine fans £1 each
Screen wash bottles £1
Zetec airbox £4
N/s genuine ford valeo headlight £2
2x fiesta mk3 arch liners £2 a pair
blue mk3 mirrors early type from a 1992 xr2i £4 pair
mk3 early tyre red mirror £1
mk3 early seat belt height adjusters
jvx avx11 cd/dvd player comes with remote control works perfectly but has a bad connection on the screen sometimes needs to be poppes off and clicked back on comes in orignal box remote may need a battery £30
PostPosted: Tue Jun 24, 2014 9:28 pm
Drives: 2.0 fiesta azura
Dude you got a pic of yhe steering rack limiters
blunty
PostPosted: Tue Jun 24, 2014 9:32 pm
still in packet
PostPosted: Sat Jun 28, 2014 8:02 pm
still loads left all needs to go will take £70 ono for the lot
