It is currently Fri Feb 22, 2019 11:13 pm
PostPosted: Sat Jun 22, 2013 10:10 pm
Drives: mondeo st tdci
broke the xr3i today
engine 117k good runner no smoke
engine setup £350
HO inlet manifold, ecu, engine loom, exhaust manifold, front engine mount bracket, flywheel, coil pack and thermostat housing.
mtx75 gearbox needs a new imput shaft oil seal I think.
changed gear fine and doesn't whine
£30
disc rear beam £150
air box £20 posted
130 spec maf £30 posted
intake pipe with flexi pipe £30 posted
coolant hose set ( one hose not pictured)
£35 posted
alternator £30 posted
starter £30 posted
power steering pump £30 posted
cat new one has been fitted in the past £40 posted
lambda sensor £15 posted
back box £30 posted
mk5 escort strut brace
£35 posted
mk5 electric mirrors in good working order
£40 posted
abs master cylinder and servo £40 posted
abs pump £30 posted
abs ecu £20 posted
escort rs accessory rear spoiler
captive nut has been pulled £35 posted
rear bumper spats
£25 posted
rs accessory side skirts
one end needs repairing £40
front hubs with abs £40 posted the pair
260mm brakes £70 posted
front shocks £50 posted the pair
rear cabby shocks £25 posted the pair
rad £25 posted
fan £15 posted
front door cards
£30
pas rack £30
arb with brackets £25 posted
rear engine mount £25 posted
gearbox mounts £30 posted
front bumper indicator £15 posted
front bumper fog light £15 posted
pas reservoir £10 posted
