It is currently Wed Jan 24, 2018 12:45 am
PostPosted: Thu Apr 18, 2013 9:50 pm
Drives: mondeo st tdci
having a good clear out
can be collected from sp40je or cf37 3lb by prior arrangement
zetec rear engine mount £20 posted
rs1800 zetec drive shaft (short one sold)
£20 posted
mk3 fiesta handbrake cable brand new £15 posted
rs turbo crossover pipe £15 posted
mondeo st clock facier £10 posted
pipercross cold air feed new in box.
internal pipe diameter is 50mm
outer diameter of the trumpet is 82mm
£17.50 posted
coil packs from 1.8 /2.0 ltr zetecs £10 posted each (only two left)
silicone 90 degree bend 86-74mm £10 posted
nImage
bosch cvh dizzy £20 posted
ramflo air filters to fit twin 40 carbs with gaskets good condition £35 posted
mk3 zetec exhaust nearly new £65
alloy catch tank £30 posted
fiesta mk3 master cylinder good condition no leaks £20 posted
mk3 rs1800 gearbox good overall condition no rattles or whines £50
mk3 fiesta power steering setup
comes with all pipe work, rack, front zetec engine mount, pump, resviour, steering column, gaitor. £120 posted
PostPosted: Fri Apr 19, 2013 10:11 pm
ripspeed 4inch coaxial speakers as new x display items ideal for the rear of a mk2 fiesta £20 posted
fiesta rs turbo steering wheel will need a clean and feed £35 posted
PostPosted: Tue Apr 30, 2013 9:26 pm
rs1800 rear shock and springs good overall condition springs look to be not very old £25 posted
rs1800 front anti roll bar with brackets and bushes £25 posted
fiesta zetec fuel line connectors from the engine bay £10 posted
mk3 clock with silver lockwood dials rev counter needle has been stuck back on £15 posted
mk3 centre console with boot release button and leather gaiter £20 posted
richbrook gearknob few scratches around the sides £10 posted
rs1800 rear beam with arb. brakes and cylinders seem to be very new £80 collected
PostPosted: Wed May 01, 2013 9:29 pm
good condition sunroof with seal £25 collected
PostPosted: Thu Jun 06, 2013 10:29 pm
bump
PostPosted: Sat Jun 08, 2013 8:48 pm
Big g... wouldnt mind the fuel lines, cold air feed, speakers and handbrake cable?
