It is currently Wed Sep 19, 2018 4:02 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
PostPosted: Thu Jan 03, 2013 1:09 am
see below for updates
TEAM AUBERGINE
PostPosted: Thu Jan 03, 2013 1:10 am
continued:
TEAM AUBERGINE
PostPosted: Thu Jan 03, 2013 1:11 am
keep going keep goin! :D
TEAM AUBERGINE
PostPosted: Thu Jan 03, 2013 1:14 am
i'll sort a deal with you on multipurchase....
all parts quoted with out postage
large items are corrior (£12 p&p mainland Including lower of scotland) couple of items can be corriored together for that price
very large items i'e pannels, doors etc about £20+ depending
all items old as seen any intrest questions etc just ask.
or call sam on #0781 366 9260 no texts or your be classed as messers as had alot of that before.
I CAN TAKE PARTS TO FITP!
price list guidelines;
richbrook valvecaps new £2
cat 1.6 si £65
ford steering wheel xr2i rs1800 etc £25
rs lifting eyes pair £10
odd middle pillar trims £5 each
rear door quater pannel trims £10 per pair. 2 pairs avalible
door pockets pair with electric window switch holes £5
electric window switches £3 each (6 avalible)
roof grab handles £1 each
screen wash cover std £1
sun visors with mounting brackets each £2 without brackets £1
sun visor clip in brackets £1 each or free if with visor
rear wiper motor £10
mk3 gear nob oem £2
centre console bracket £3
hand break handle £1
fag rear quater inserts £1 each
3.5 mirror outer casing £3
header tanks £10 (2 avalible)
egr valves (2 avalible)
blanked off middle pillar trims for harnesses. £5 each or £8 pair
nsf passanger footwell bracket (found under carpet) £5
standard radio £5 with code
ford steering wheel with airbag. £10
standard zetec exhaust manifold. £25
rubber cat hanger rubbers £2 each
standard xr2i rear spoiler £10
centeral locking motors attached to interia handles £10 each or £18 pair
alarm with remote entry £20
compleate rear boot wiring and motor £25
various boot parts loose; security covers, rear quater breathers £1 each
boot catch £4
compleate set of alloy wheel nuts and lockers £15
full lock set and ignition and 2x keys £15
rear seat belts full £15
blue mk3 door £10
footwell trim xr2i/ frst style £15 pair
drivers side front pillar trim £5
inner wheel arch covers front £10 pair
glove box door £5
mk3 rear pillar trims £10 pair
inner rubber window seals (top of front door cards) £5 pair
pair of mk3 middle pillar trims (one has screw pulled through) so £5 pair
front wippers pair £5
front headlights £5 each
mirrors £8 pair or carbon effect £15 pair
orange indicators front and sides (front ones have odd wear on inside)£8
windscreen washer bottle £5
mk3 wishbone carriers £5 pair
kenwood tape player inc leads £8 (leads worth that alone as they fit the cd ones)
ht leads zetec
gearbox mounts £10 pair
gearbox air duct (non turbo engines) £1
drop links £1 pair
bonnet catch support bar £2
mk3 strong boot hydrolic £8
rear speakers and mounts for rear parcell shelf etc £10 pair
non egr exhast manifold zetec £15
std airbox zetec £5
airbox bracket part £1
heater matrix leaf cover £2
scuttle pannel +rubber £10
airbag control moduel £3
escort brake resivior with cap £5 (also fits on top of mondeo brake servo)
resivior plug caps £2 each
non abs mk3 fiesta set up £10
s braces £5 each
rad £10
gear linkage £20
gearbox cradle £10
empty cat £5
rear drum brakes £10 pair
roof areil £2
behind the dash plastic heater pipes £3
rear boot lid trim £3
bonnet hings £2 pair
charcole can £2
heater box linkages and sliders £2
pedal box mk3 £10
fuel filter and bracket £2
zetec cam cover £2
clutch / spedo cables £4 each
zetec fan £5
steering colum manual steering and mk3 surround
rear back box magnetex stainless £45
wiper moter and mech/ linkage setup front £15
front engine mount compleate £10
bonnet catch and cable £4
electric window mech £10 each or £15 pair
various fuel pipes £5 pair
mk3.5 zetec 1.6si alternator worked great! £20
brand new fag lighter and set up £5
clocks with glass seperated £1
1.1 +1.3? fiesta fan £2
fiesta mk3 mk3.5 window rubber £2
ford fiesta si front arch splats pair £5
odds and sods and (the well i hope you can 'identifys'):
hcs rocker cover and rockers 1.1? 1.3? mk1? mk2? mk3?
odds i know the long bracket is off a mk3 si 1600 brake servo to steering rack bracket
inlet? hcs? 1.1? 1.3?
hcs 1.1 1.3 alternator
coil 1.1 1.3 hcs??
dizzy off hcs?
mechanical fuel pump off something>
oil pump.... hcs??
apparently a escort powersteering type auxilarybelt tentionor (was ordered by mistake for my si) new £60
some door rubber not sure what off!?
some door rubber not sure what off?!
Wire with eylets either end? brakes mk3 fiesta new £5
cheers sam
#0781 366 9260 call between 9am and 10pm
TEAM AUBERGINE
PostPosted: Mon Jan 07, 2013 8:59 pm
both window regs sold
steering cowlings sold
batt bracket sold
1x s-brace sold
body kit sold
interia light sold
dash sold
clock surround sold
rs2000 disks and calipers sold
rear brake lights sold
interia mirror triangle trims sold
gearstick gattor sold
TEAM AUBERGINE
PostPosted: Tue Jan 08, 2013 12:17 am
Bumpers sold? I actually just want the fogs and driving lights.
And maybe the bootlid, without glass and 'trimmings'.
PostPosted: Tue Jan 08, 2013 11:57 am
Drives: 1.6 Fiesta Si
Hi mate would you sell the hangers that bolt on the s brace ?
cheers
PostPosted: Tue Jan 08, 2013 8:34 pm
still got bumpers
still got bootlid
TEAM AUBERGINE
PostPosted: Tue Jan 08, 2013 8:36 pm
cheers
sorry fella i sold one and only have one s brace left which only has one hanger if i remember rightly!
TEAM AUBERGINE
PostPosted: Sun Jan 13, 2013 12:34 am
updated and some prices reduced
TEAM AUBERGINE
PostPosted: Thu Jan 24, 2013 6:54 pm
updates!
TEAM AUBERGINE
PostPosted: Fri Jan 25, 2013 6:02 pm
Hiya,
How much for the arch liners delivered? I appear to have chucked one of mines out in a moment of rage :D
Paul
Hiya,
Paul
PostPosted: Sat Jan 26, 2013 7:37 pm
elPaulio wrote:
Hiya,
Paul
arch liners £5 postage corrior will be £13 though!
so £18 posted
TEAM AUBERGINE
PostPosted: Sat Jan 26, 2013 10:15 pm
more added! and updated!
TEAM AUBERGINE
PostPosted: Sat Mar 16, 2013 8:33 pm
Drives: Fiesta RS Turbo
do you still have the front heated screen?
PostPosted: Sun Mar 17, 2013 11:15 pm
Drives: 1.6 si, mk2 fez
Hello, do you still have steering column and do you have steering cowling ?
Also pm'ed, thanks !
I WANTS BOOST!
PostPosted: Mon Mar 18, 2013 9:23 am
Hi Sam,
Do you have the starter motor? Mines is now royally forked!
If you do let me know and i'll have the arch liners with it..
Paul
PostPosted: Thu Mar 21, 2013 12:32 pm
hi mate do u have front bumper with fogs and rear bumper
