It is currently Wed Feb 20, 2019 11:14 pm
PostPosted: Fri Jan 17, 2014 12:47 am
Drives: C2 VTS
In short does anybody have any ideas to help.
I have a great netbook but with the usual 1024x600 screen and have sourced a 1366x768 screen.
Now its not and exact match in fitting, I have figured the best way to mount it in the chassis of the lid but this will mean its approx 5mm lower.
I am thinking of just black tape over the silver edge for the gap at the top but the bottom will need some plastic removing. So I need to extend the hole but also do it straight and as neat as possible.
An ideas on the best execution of the above (tools etc) or a better plan altogether?
PostPosted: Fri Jan 17, 2014 2:40 pm
Steel rule and a stanley knife to make a v-shaped notch where you want cut off then use a dremel to cut and emery paper to smooth the cut edge off.
Best way I can think of, but need to be careful when making the first cut with the stanley knife that it doesnt slip as it will need a good bit of pressure to cut a decent notch in it.
Would recommend trying to get a spare bezel off of ebay to practice on.
Paul
PostPosted: Fri Jan 17, 2014 10:48 pm
Drives: C2 VTS
That makes sense I have all sorts of broken laptops so will try on one of them before the real deal.
Waiting for a cable extension now, as plug is in a different place, I will say I tried the new screen and the difference really is massive so looking forward to the upgrade.
PostPosted: Sun Mar 30, 2014 10:08 pm
Drives: Shitroen VTS
Dremel and attachments.
Best tool I ever bought.
PostPosted: Mon Apr 07, 2014 10:10 am
what this man said!
except Stevie Wonder could cut stuff better than I could :lol:
