It is currently Tue Aug 11, 2020 4:50 am
PostPosted: Tue Nov 12, 2013 9:43 pm
Hi
I have a 1300 single point injection mk3, and eventually want to 2 litre silvertop, but for now i need the car and just want to do little steps so the car is off the road as least as possible so my plan was to go si 1600 zetec while i build up a decent spec 2 litre and get the last couple bits to convert it. So my question is am i right in thinking if i was to get a 1600 si dona car and strip my engine bay down and then just move the si bits in to mine, or is it more simple to just buy the bits i will need.
Thanks Ben
PostPosted: Tue Nov 12, 2013 10:35 pm
Drives: C2 VTS
If you can get a cheap 1.6 Si rotter then go for it, it would certainly be easy knowing you have everything you need.
PostPosted: Tue Nov 12, 2013 10:57 pm
yeah that's what i thought but they dont seem to be that easy to get hold of so does anyone have a list of bits from an si i would need to put a 1.6 zetec in mine, engine obviously ill use my gearbox do the shafts or gearbox mounts need changing ?, radiator engine loom ecu engine mount anything else that i will need ?.
PostPosted: Wed Nov 13, 2013 10:47 am
Remember that there are also the late 1.6 Ghias which have the Zetec engine in them, they may be easier to get hold of as they aren't an "Si".
Any engine change is easier with a donor car sitting next to your car as you can see how everything mounts and what runs where.
Off the top of my head parts you would need are:
Engine block, exhaust manifold, inlet manifold, injectors, radiator, hoses, wiring loom, ECU, fuel tank, fuel pump, fuel lines, engine mounts, and there are probably more.
Paul
PostPosted: Wed Nov 13, 2013 7:24 pm
ah ok then mate ill keep an eye out for a ghia aswell, and can i not use my tank and fuel lines just use the zetec fuel pump as mine if already injection so should have the return fuel lines and stuff ?.
PostPosted: Wed Nov 13, 2013 9:23 pm
You possibly can use your tank, I didn't twig that you had injection at the time I was writing the above, would maybe need a bit more digging as I'm only going on what I can remember about what I have read online as I have never had to go from Carb/SPI to EFI so don't know for sure what is needed tank wise.
Cheers
Paul
PostPosted: Thu Nov 14, 2013 12:46 am
fair enough i think its worth getting a dona car that way i have everything if needed so, i either want a scrap si or a mk4 ghia ?.
PostPosted: Thu Nov 14, 2013 10:33 pm
No a Mk3.5 Ghia a Mk4 will have a Zetec-S engine which is no use.
Any 16v Mk3/Mk3.5 fiesta will give you what you need to get a 2.0 in your car
PostPosted: Sat Nov 16, 2013 11:56 am
cheers for your help mate appreciate it
PostPosted: Sat Nov 16, 2013 7:00 pm
No worries, it's what were all here for :thumbsup:
Just keep asking loads of questions, there will be someone here who has done it/seen it/read about it who can help you out ;)
Cheers
Paul
