It is currently Wed Sep 19, 2018 6:01 pm
 Post subject: Lowering springs ?
PostPosted: Wed May 16, 2012 8:58 pm
Drives: MK3.5 Fiesta SI
Is it true that -60mm lowering spring's and all lowering springs in general are just standard springs, That have been cut, Heat treated to stiffen them and then re-painted.....
I have -60mm springs in my mk3.5 and i have cut one coil off each, Been in use for around 2000miles not had a problem, And a friend has asked me to cut one coil off his -35mm springs is this "UN-SAFE" or is it okay as long as you don't start cutting the springs to short ?
We both run shortened shocks so no chance of them falling out,
Any advice would help
cheers kieren
WANTED:
MK3 fiesta lower strut brace/S brace
MK3 fiesta Rear ARB with mounts
MK3 fiesta Front upper strut brace
 Post subject: Re: Lowering springs ?
PostPosted: Wed May 16, 2012 10:36 pm
Drives: C2 VTS
I must say you should never cut springs, they are designed to work as a complete unit.
It can cause the springs to pop out of place which is highly dangerous when driving.
As it is lowering springs are manufactured to me lower and aren't just standards which have been cut.
PostPosted: Thu May 17, 2012 8:39 am
Drives: 08 Ford Focus 2.0
chopped springs :doh:
buy proper springs people :sigh:
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Wed Jun 20, 2012 10:21 am
cheers kieren
there a suspention kit i might be buying soon so if you want to buy my springs off me -35mm then you can have them for 25 quid. set of 4 and about 3000 miles. :thumbsup:
TEAM AUBERGINE
