It is currently Tue Feb 20, 2018 8:47 pm
 Post subject: shift..........
PostPosted: Tue Apr 24, 2012 8:41 am
ok so basicly i usualy shift up gear about 2500-3000 rpm when ploding about.
if i'm going for it i usualy shift up gear at 4000 rpm
is 4000 rpm to high (am i thrashing it?) or that ok?
also what rpm you shift up on or you do it by ear?
TEAM AUBERGINE
 Post subject: Re: shift..........
PostPosted: Tue Apr 24, 2012 9:37 am
I usually shift when I hit the limiter :) 7200 rpm ftw. Sometimes I shift up at between 6-7,-000 rpm. You basically need to find out when your engine runs out of puff and then shift up just after that.
Zetecs usually run out of puff about 5500 rpm (i think) and thats when the most power is there too. So your shifting quite early really.
The higher rpm you go to, the more engine speed you carry into the next gear, so you will effectively get more speed more quickly in the next gear. But with the 1.6, after about 5500rpm. But you dont want to be sitting in the same gear thinking 'i need to hit 7000rpm' if its going to take an age, because thats time and speed lost in the next gear.
You wont do any damage to the engine reving it high, engines are designed to do that, and the limiter is there to stop it over-revving and things going wrong.
Also, if you have a little search of the forum, this has been asked about 48,972 times lol
PostPosted: Tue Apr 24, 2012 9:56 am
Drives: Si 1.6 & ST170
Basically as danny said, 4000rpm is too low, factory figures for zetec say 5500rpm it stops pushing so go a little bit above so when you change gear you remain in the power band.
I rev my focus to above 7200rpm so when I shift my next gear is still in the high rev range to keep the power on because in the low rev range its a town plodder lol.
Just do some research where your power starts and finishes, also keeping an eye out for flat spots.
The Loumiester wrote:
PostPosted: Tue Apr 24, 2012 6:47 pm
Lol wtf!? 2500-3000 plodding about?
Well, I plod at 1750 or so on gear changes, but I do hit 5500-6000 when I want to make chavs cry.
PostPosted: Tue Apr 24, 2012 7:46 pm
Drives: Jap Crap
You need to shift after you see the tacho go past 9000rpm :)
Oh wait, you don't have a girly torqueless wonder machine :teehheee:
On a serious note, I found between 4000 and 6000 (maybe a tad more) was the sweet spot for my old Fiesta.
PostPosted: Tue Apr 24, 2012 8:54 pm
Drives: C2 VTS
In my fiesta it was around 6.5k but it was cammed so not the same.
The C2 is change when it hits the limiter.
PostPosted: Wed Apr 25, 2012 12:16 am
had the needle twatting the plastic on a couple of occasions in my si. but i found it used to bang nicely between gearchanges at about 5500 rpm (superchipped with single box exhaust)
the more i think about it the more i miss the noises that dirty little money pit made :lol:
PostPosted: Wed Apr 25, 2012 5:12 pm
lol ok fellas cheers
TEAM AUBERGINE
