It is currently Sat Apr 21, 2018 11:44 pm
 Post subject: RS2000 Side Skirts
PostPosted: Sun Mar 13, 2005 1:56 am
Does n e 1 on here have RS2000 side skirts?
Does n e 1 have trouble with jacking up the car?
Plz let me know thanx peeps :)
8-)
PostPosted: Sun Mar 13, 2005 2:16 am
Drives: Nissan Pulsar GTi-R
I dont personally, but get yourself a trolley jack anyways :D
Much sturdier and I have a lot more confidence in them than the standard Ford one - they're really only for emergencies :)
PostPosted: Sun Mar 13, 2005 10:10 pm
i never jack the car up from the sides , wouldn't use the ford jack anyway.
i lost it for weight saving :lol: :lol:
join a recovery service its the best way :P
PostPosted: Sun Mar 13, 2005 11:47 pm
I'm with the AA n e way :) But I woz thinking of getting a low trolley jack :) coz then I can (or my boyfriend like he did last time not bad tho only had the 1 puncture *touches wood*) still change my tyre n e way.
8-)
PostPosted: Sun Mar 13, 2005 11:48 pm
i dont jack my car up from the side no more either after it fell off the jack n the jack went through the floor :lol:
PostPosted: Sun Mar 13, 2005 11:51 pm
So if u don't jack ur car up from the side where do u jack the car up from? the front & back of it?
8-)
PostPosted: Mon Mar 14, 2005 1:22 am
i jack my car up no problems with my mates trolley jack, and i've got 12-bore sideskirts (which are pretty low) on 16's. Might have some problems when its lowered, we'll wait and see.
I think he got it from Argos (don't laugh) and theres an RAC trolley jack with 2 axle stands for ?30! We've been using them loads recently and no problemo's atall yet.
Hope this helps
PostPosted: Mon Mar 14, 2005 1:40 am
Drives: BMW E90 330D M Sport
Yes, ive got RS2000 sideskirts and also have problems jacking the car, thats cause they dont fit flush to the underside of the car and weather you use the ford jack or a trolley jack you'll crack the skirt, have to keep taking them off ! :(
PostPosted: Mon Mar 14, 2005 1:52 am
So if u have 2 keep on taking urs off? R urs easy 2 take off? Plus does different peeps fit them 2 the car differently if so how r they fitted 2 the car (as I know there r a few ways)?
8-)
PostPosted: Tue Mar 15, 2005 12:20 am
Yer just 3 bolts running down the side of the skirt, takes about 5 mins to remove, until i fix them on properly on so that it can be jacked without removing them, dont need to jack the car up often so not too much of a problem
PostPosted: Tue Mar 15, 2005 1:23 am
yeah jack your car up from front or back, can do this when changing a wheel aswell
if your working on it you should jack it onto stands so will be able to do that from front or back
generally use the rear chassis rails on the back.
the gearbox cradle on the front or the lower arm to chassis leg points on the fronts
PostPosted: Tue Mar 15, 2005 1:26 am
Where bouts would I find them? Sorry but I'm not that fimiliar with under my car only ever seen it in a pic in the haynes manual & once quickly when I had my tracking & steering wheel aligned.
8-)
PostPosted: Tue Mar 15, 2005 1:31 am
right best way is to lock but i'll tell you where look under the back from the back bumper and you'll see to supporting rails, box like sections those on the rear and on the front if you look at the towing eye and go directyly back that where the gearbox cradle is and the lower arm to chassis rails you'll be able to see the lower arm joins the bottom of the suspension setup and the the car the car/arm join is whwere you can jack
PostPosted: Tue Mar 15, 2005 3:10 am
Thanx 4 that :) U've been really helpful on this matter :)
8-)
PostPosted: Tue Mar 15, 2005 4:16 am
Tony made a helpful post :o
Post Whore
PostPosted: Tue Mar 15, 2005 9:49 am
Drives: V70 T5
tony in helpful(not random) post shocker :o
PostPosted: Tue Mar 15, 2005 12:34 pm
fook me, u feeling alrite tony mate? :?
Users browsing this forum: Google [Bot] and 3 guests
