It is currently Sun Jul 22, 2018 5:46 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Thu Feb 12, 2009 2:45 pm
Drives: FORDS
OK random conversation with Meilack started this thread but curious now to everyone's opinions on this!
I will start the following to, add yours to the list. :D
1. Bracket in the middle of the car to stop centre sectiono of exhaust dropping.
2. a 2ltr fiesta mk3
3. Bring back the cosworth engine
4. Rust proofed older fords properly :rolleyes:
5. Not invented the clutch ratchet system used on mk4 escorts and mk3 fiestas etc :x :lol:
6. Used the mk3.5 style filler flap on the mk3 fiesta :rolleyes:
7. Not used the driveshaft driven ABS System on older fords :0 :lol:
8. used a non dizzy engine management on cossies :lol:
9. used the efi management on S2 rs turbos as mfi was unreliable :doh:
10. made the Fiesta ST faster :doh: to match the chassis :rolleyes:
11. desgined the BC gearbox better so it wasn't so notchy and prone to crapping itself :doh:
12. shot the person who designed the 3 spokes for the FRST :lol:
13. not bothered developing and selling the probe :halo:
14. made seats and other interior parts that don't squeak and rattle :lol:
15. put the XR/RS arches on the Si in the first place :lol: :)
16. not used the fiat 500 as a base for the new KA :rolleyes:
17. Not used dodgy wiring on old escorts, especially for heated rear screens and rear clusters :doh:
18. Given the FRP more blooming power as that does have an excellent chassis :cry:
19. Read above for mk5 fiesta zetec s :cry:
20. Made more mk1 Focus RS's :cry:
21. not made brake lines go over the fuel tank (eh des?) :lol: :halo:
22. Not put the starter on the exhaust manifold side of the Escort RS/XR range as the engine heat roasted the starter motors :x
23. Used better quality standard discs as the normal ford ones on older fords were prone for warping :lol:
24. Used better quality seals on mk4 xr3i cabrios, as the underneath was top notch with double skinned sills
25. Made a fiesta cosworth, there's pretty much everything else except during that time
26. made better sun roof seals
27. strengthened the mk3 like the 3.5 was. i.e side impact bars
28. make an xr8 in this country
29. make xr6 turbo in this country...mmmmmmmmm
30. better rear light seals :doh:
31. spare wheel inside rather than underneath so everything doesn't rusts and tyre perishes
32. external pats across the board on zetec ecu's
33. made the third gear syncro on Fiesta ST's properly on 2008 models :squint:
34. Made the dealers more friendly and less tosserish :cry: :rolleyes:
35. Changed the design on mk4 escorts where the gear linkage is directly above the exhaust, so you have to hang the exhaust low to clear it properly
36. not use that stupid measly jack that is meant to jack up on a sill which you know will probably split of bend a little with the weight of the car
37. better bottom arms, you don't hear of any other makes changing them every few months
38. thrust bearing linkage in BC gearbox have two holding pins instead of one so less likely to have chatter from it as you accidentally put it in not equal so need to take the entire thing of again :doh:
39. bottom ball joint pins - why do they have to be torque bit on the end which always round if haven't been undone for a few months
40. why do you have to take the centre sub frame section of the si to get the cat down :x
41. why use leaf springs on the mk5 & 6 vans :?
42. Have to take headlight out to change bulbs on mk5 fiesta.......why? :x :lol:
43. Wiring loom on mk4 escort and mk3 is one piece from headlight to rear light :x :lol:
44. Made an RS Turbo cabriolet available to public to buy :halo: :thumbsup:
45. not put the boot release in the middle on mk6 escorts as they work with the ignition on and "funny" mates open your boot at will :rolleyes: :lol:
46. made 90 spec boots on escorts slightly different :x :lol:
47. made the ride height on standard pumas lower to reduce arch gap!
48. made more S1 RS Turbos
49. Not used the EGR System as found on the Si :doh:
50. made the trip computers on S2's actually semi accurate :lol:
51. why rivet window regs in to door when you can buy replacements from ford becuase they are obviously going to fail at some point...did it save money riveting...no!!!!
52. Gearing on the Fiesta ST is to short :rolleyes:
53. Recaros for above are shockingly expensive :shock:
54. Gearing on the Fiesta ST is to short :rolleyes:
55. Recaros for above are shockingly expensive :shock:
56. fuel pump bracket on Mk4 rs...who designed it to bolt up the way it does...tiny bit of rust hits those bolts the don't come off and you need a new one. :doh: i speak from a nightmare of experience.
57. why spend millions designing the rs2000 engine and only use it in one car :?
PostPosted: Thu Feb 12, 2009 2:50 pm
Drives: FORDS
NONE FORD DRIVERS CAN NOT POST :lolz: :lolz: :lolz: we are aloud to abuse we drive them...you dont :insanity:
Thank means the French Car Boys (this thread is probably heaven to you) :look: :look: :look:
PostPosted: Thu Feb 12, 2009 2:52 pm
Drives: 08 Ford Focus 2.0
blimey i'll stop
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Thu Feb 12, 2009 3:02 pm
more
* used a non dizzy engine management on cossies :lol:
* used the efi management on S2 rs turbos as mfi was unreliable :doh:
* made the Fiesta ST faster :doh: to match the chassis :rolleyes:
* desgined the BC gearbox better so it wasn't so notchy and prone to crapping itself :doh:
* shot the person who designed the 3 spokes for the FRST :lol:
* not bothered developing and selling the probe :halo:
* made seats and other interior parts that don't squeak and rattle :lol:
* put the XR/RS arches on the Si in the first place :lol: :)
* not used the fiat 500 as a base for the new KA :rolleyes:
* Not used dodgy wiring on old escorts, especially for heated rear screens and rear clusters :doh:
* Given the FRP more blooming power as that does have an excellent chassis :cry:
* Read above for mk5 fiesta zetec s :cry:
* Made more mk1 Focus RS's :cry:
* not made brake lines go over the fuel tank (eh des?) :lol: :halo:
* Not put the starter on the exhaust manifold side of the Escort RS/XR range as the engine heat roasted the starter motors :x
* Used better quality standard discs as the normal ford ones on older fords were prone for warping :lol:
* Used better quality seals on mk4 xr3i cabrios, as the underneath was top notch with double skinned sills
I'm letting off steam :lol:
PostPosted: Thu Feb 12, 2009 3:33 pm
Drives: FORDS
More again:
* Made a fiesta cosworth, there's pretty much everything else except during that time
* made better sun roof seals
*strengthened the mk3 like the 3.5 was. i.e side impact bars
*make an xr8 in this country
*make xr6 turbo in this country...mmmmmmmmm
*better rear light seals :doh:
*spare wheel inside rather than underneath so everything doesn't rusts and tyre perishes
* external pats across the board on zetec ecu's
PostPosted: Thu Feb 12, 2009 3:34 pm
blimey thats quite a few just between me and you! :red:
* made the third gear syncro on Fiesta ST's properly on 2008 models :squint:
* Made the dealers more friendly and less tosserish :cry: :rolleyes:
* Changed the design on mk4 escorts where the gear linkage is directly above the exhaust, so you have to hang the exhaust low to clear it properly
PostPosted: Thu Feb 12, 2009 3:39 pm
Drives: FORDS
:lolz: :lolz: :lolz: Meilack, think you got a few issues with fords :insanity:
I just though of another one tho...
* not use that stupid measly jack that is meant to jack up on a sill which you know will probably split of bend a little with the weight of the car
PostPosted: Thu Feb 12, 2009 3:40 pm
i don't :lol: i love fords :D
just pointing out a few things :red:
consolidate all of them in the first post numbered, so we can see how many :rolleyes: :lol:
PostPosted: Thu Feb 12, 2009 3:48 pm
Drives: FORDS
:lol: imagine how many when others post as well :lol:
* better bottom arms, you don't hear of any other makes changing them every few months
* thrust bearing linkage in BC gearbox have two holding pins instead of one so less likely to have chatter from it as you accidentally put it in not equal so need to take the entire thing of again :doh:
* bottom ball joint pins - why do they have to be torque bit on the end which always round if haven't been undone for a few months
* why do you have to take the centre sub frame section of the si to get the cat down :x
* why use leaf springs on the mk5 & 6 vans :?
ill put them all in the first post now...best give me half hour :lol:
PostPosted: Thu Feb 12, 2009 3:57 pm
yeah and if the french crew get on to it, hundreds will materialise :lolz:
* Have to take headlight out to change bulbs on mk5 fiesta.......why? :x :lol:
* Wiring loom on mk4 escort and mk3 is one piece from headlight to rear light :x :lol:
* Made a mass produced commerically available RS Turbo cabriolet :halo: :thumbsup:
PostPosted: Thu Feb 12, 2009 4:00 pm
Drives: FORDS
* Made an RS Turbo cabriolet :halo: :thumbsup:
will add these now...we are at 44 between us :lol:
ive got a mk4 loom out of my cab in the garden...i no how you feel there.
and they did in fact make an rs Turbo cab...made fu*k all and public couldn't by them :x
PostPosted: Thu Feb 12, 2009 4:02 pm
yeah thats what i remvoed the loom on, what a fecking biatch! :x
fine i'll edit my quote on the RST Cab :P
PostPosted: Thu Feb 12, 2009 4:05 pm
blimey, thats quite a list :shock:
* made the ride height on standard pumas lower to reduce arch gap!
* made more S1 RS Turbos
* Not used the EGR System as found on the Si :doh:
* made the trip computers on S2's actually semi accurate :lol:
PostPosted: Thu Feb 12, 2009 4:06 pm
you 2 are on a roll :lolz:
PostPosted: Thu Feb 12, 2009 4:07 pm
well every little thing that nagged me i have put :lol: and other things i think should have happened :lol:
you got any cossie based issues to add? :P
* not put the boot release in the middle on mk6 escorts as they work with the ignition on and "funny" mates open your boot at will :rolleyes: :lol:
* made 90 spec boots on escorts slightly different :x :lol:
PostPosted: Thu Feb 12, 2009 4:30 pm
Drives: FORDS
already done that for you :P
Made an RS Turbo cabriolet available to public to buy :halo: :thumbsup: which is still a gripe with ford i think.lol
there's more to come im sure :lolz:
added to list
PostPosted: Thu Feb 12, 2009 4:31 pm
Drives: FORDS
I cant wait till the French boys see this thread, there gona double that list and probably piss themselves :lol:
PostPosted: Thu Feb 12, 2009 4:33 pm
you missed a couple of mine :cry: :lol:
so here they are :P
PostPosted: Thu Feb 12, 2009 4:35 pm
i feel responsible for the majority of these points :red: :lolz:
PostPosted: Thu Feb 12, 2009 4:38 pm
Drives: FORDS
so here they are :P
Just realised.lol
* why rivet window regs in to door when you can buy replacements from ford becuase they are obviously going to fail at some point...did it save money riveting...no!!!!
